Thread: my pump got half submerged and tripped the circuit
    we got a massive rain and because our pool is still under construction the pump and filter are down in a area that ended up flooding and the pump was half submerged when it tripped the circuit. is it gonna be ok?
    Seafarer 32,500 gallons; Haywood (s244T)Sand filter; In ground, vinyl liner: 1 HP Haywood pump: Pool age approx 15 years
    38,548
    Re: my pump got half submerged and tripped the circuit
    Hard to say. they are certainly not meant to get that wet. Can you make them replace itas you have not taken delivery of the completed pool?
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    If you have not completed construction, the builder still owns it and it is his responsibility. That is my understanding. Just don't accept the equipment or make final payment until you are satisfied.
    -- Guy --
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    pumps are amazing, but in your circumstance I would try to get a new one. I have a pump under my pool house running my pond and it was completely submerged with power off. I wan't home at the time, otherwise I would have removed it and taken it apart and ran a VERY HIGH POWERED fan on it for hours. They just untripped the breaker and it's running like it never happened since then. Now that's lucky!!!
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    Jun 2007
    New Jersey
    653
    Hurricane Floyd flooded my equipment pit and killed power to the sump pump while I was away. The Hayward pump motor was probably under water for two days. It was never under power when it was wet because the water only rose when the power went out (I assume this was the case--that sump pump had done its job through floods and hurricanes for 20 years.) The Hayward ran once I dried it out with a box fan for 24 hours, but it died in the middle of the following season.
    I'd insist on a new pump. I doubt there is much difference between two days and two minutes.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I had not noticed this before, you said it tripped the circuit. This means something was under load when it blew the circuit and something likely "died" in the process to shorting. I would have them replace it in your yard and their insurance can cover it.
    This is what I expect a reputable construction contractor to do.
    -- Guy --
