Thread: Hayward Variable Speed Pump Controled by Pro Logic
    I have a hayward SP3400VSP and a Aquarite Pro Logic Control (PS4), I dont know how to wire the low voltage communications side can anyone help?
    I have the 22V connected and wired through the aqurite relay 1, but need help with the low voltage side of it
    If anyone has done one and has a Picture or a diagram that would be great
    Thanks
    Re: Hayward Variable Speed Pump Controled by Pro Logic
    The pump control wiring is shown in the pump manual on page 14, section 4.3.
    By the by, when using a variable speed pump you do not wire AC power to the pump through the pump relay. Instead the pump is wired directly to the circuit breaker and the low voltage control wiring turns the pump on and off.
