Thread: Lower temp without raising TA
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    My numbers are all right where I want them, but the water is seriously warm. I have an aerator, but I don't want to lower my TA any more than it already is. What can I do? Thanks for any advice!!
    1992 15X30 14000 Gal IG plaster, Pentair 011018 - Intelliflo VS Pump with Timer, 350 lb Sta-rite hrpb30 sand (yeah, the 32-bolt clamshell)
    Re: Lower temp without raising TA
    There isn't any other easy way to cool the water, unless you have solar panels or a heat pump with a cooling mode. Besides, it is easy and inexpensive to raise TA if it gets to low.
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Quote Originally Posted by Spiccolli
    I've read here that running a fountain or aeration device *at night* works well. I use one at times in the daytime so I can't attest to the nighttime but it sounds reasonable.
    Just keep an eye on your pH and TA but those are both easy to maintain or tweak if it came down to it.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I can vouch for the effectiveness of running a fountain or other aeration device at night. On the advice of a friend, I began running the pump at night from mid-July until around Labor Day of last year. The aeration from the overflow waterfall from the spa to the pool provided enough of a cooling effect to lower the water temp about 4-5 degrees - not a lot, but noticeable. Plus, some electric utilities offer off-peak rates. That might be worth checking into in your area.
    I have recently started this process again this year. As previous posters stated, pH and TA are relatively easy to manage.
