Thread: Aqua Genie Weir
    Apr 2012
    South Dakota
    87
    Aqua Genie Weir
    The weir on my skimmer sticks. If I push it closed it does swing free until it a certain point then sticks. I assume it should flow up and down freely?
    18600 Gallon In Ground
    Vinyl liner
    Aqua Genie Skimmer/Return
    Purex Triton Challenger wet end with Emerson 2EZ Speed Two-Speed with Timer Motor 3/4HP #EB2980T
    Sta-Rite 145361 Cristal-Flo II High-Rate Sand Filter 22Inch
    Taylor K-2006
    38,547
    Re: Aqua Genie Weir
    Correct it should move freely. Are the sides bulging in causing it to catch on the sides or what is causing the catch?
    You may be able to just trim the sides of the weir a bit.
    Apr 2012
    South Dakota
    87
    Re: Aqua Genie Weir
    I have felt the sides and I don't feel any noticeable bulging. How is the weir removed?
    Vinyl liner
    Taylor K-2006
    38,547
    Re: Aqua Genie Weir
    Most original ones are attached with screws from inside the skimmer hole.
    One of mine used to have plastic pins that the door rotated on. They started to break down and not rotate well anymore.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    22,553
    Re: Aqua Genie Weir
    I think the AquaGenie uses two pins and a spring to hold them in place.
