Thread: need help on above ground refill
    Sep 2007
    middle tennessee
    38
    Hello,,need a little help..been using the BBB method about 4-5 yrs...clear and great..now, BUT getting ready to replace me leaking liner ..my question,,when i refill, what order do i try to balance?..clorine-salt-PH ect..THANKS
    Above ground 24'round-vinyl-14,000 gal,,1 speed-2 hp pump, 250 lb sand filter ..heated,,salted,,lighted,,decked,,with slide and pool rover jr.....
    TFP 100,,am doing the BBB thing...Wet is Wild!
    38,290
    Re: need help on above ground refill
    I think the Temporary Pool Guide gives a pretty good idea of how to restart.
    Certainly want to get some FC in there as soon as you have water circulating and then start to get the CYA in to protect it.
    Then adjust pH and maybe TA
    Salt can be done at any time.
    I think most all of that can be done almost at the same time. Do not make huge adjustments so you do not overshoot anything.
