Thread: is the pool calculator down?
    I keep getting this message:
    "Forbidden
    You don't have permission to access / on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
    Thanks!
    Lori
    Hayward S180T Sand Filter
    15 X 30 Above Ground Pool (10,600 Gallons)
    Re: is the pool calculator down?
    Yes, they are down.
    There is an alternate copy you can use as long as they are having problems at http://www.troublefreepool.com/calc.html.
    Thank you
    Lori
    PoolCalulator.com is back up now.
    Jul 2011
    Anderson SC
    3
    And down again today!
    Campground pool but not heavy usage as a rule, 36,000 gallon in-ground gunnite, sand filter (new sand May, 2011), 1.5 HP pump running 24 hours from mid-May to early September, CompuPool CPSC48 SWG, Single main drain and Vac-alert safety device, TF-100 test kit,
    And back again.
