Thread: Replacing sensor on Aquapure 1400 SWG
    Jun 2007
    Mesa, AZ
    34
    The sensor on my AquaPure 1400 needs replacing. Two different pool repair companies want close to $400 to replace it. It looks very straight forward as far as unplugging the old sensor from the circuit board and plugging the new one in. This is the newer version of the system with the rounded cell instead of the old square edged one. If I do it myslef, is there anything else I need to do other than unplugging the old sensor and plugging in the new one to replace it? Obviously, I'll make sure the power is off to the system before changing it, but are there any other steps required? I can't find anything specific in any of the manuels for the system or on any of the forum entries. I attached a pic of the circuit board with the sensor plug in. Any advice would be great.
    IG, Shotcrete, PebbleTech, 30 1/2 x 13, 13000 approx. gals, 1 1/2 HP Jandy pump, 2 1/2 plumbing, cartridge filter, SWG, ozone system, PV3 in-floor pop-up cleaning, Mesa, AZ
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Replacing sensor on Aquapure 1400 SWG
    Make sure that your sensor is set in black epoxy.
    Factory Warranty Station for:
    Jun 2007
    Mesa, AZ
    34
    yes, thanks PC. I've read that. I'm just asking about actually putting in the new sensor. Do I just unplug the old one from the circuit board and plug in the new one?
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Yes, with the power off of course.
