Results 1 to 8 of 8
Thread: What size pavers for Intex rectangular AGP?
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Hi all,
    I was wondering what size pavers do you use for Intex rectangular AGP? The supports are wider than the ones on a round pool.
    Does anyone know the measurements on the supports?
    Cheers,
    Liz
    Northern California 9 X 18 Intex Ultra Frame Pool (mint in the box), 1 hp Hayward C-400 pump & cartridge filter Twins (Boy/Girl) 10 yrs old
    Northern California Inground pool 14' by 30'
    Diamond Brite Quartz Medium Grey Plaster - Islands Sapphire Breeze Tile Border
    Jules Bright Cobalt Blue Blend Tile Bench fountain sheer waterfall descent
    Pentair Intelliflo Variable Speed Pump - Pentair CLean & CLear PLus Cartridge Filter - Kreepy Krauly Legend - mTF-100 Test Kit ™ - Swimmers: Twins (Boy/Girl) 16 yrs old
    Jun 2012
    MA
    347
    Re: What size pavers for Intex rectangular AGP?
    I think the paver thing is over done. Yes pavers work well and look good but they are overkill. Why not make some forms and pour a footing. If your ground is packed down enough you do not need any pavers. I had an Intex pool for two years with nothing under the legs. It was fine, the legs did not sink. This year I put down 1/4" plywood squares 7"-7" under the legs only because it would be easier incase I needed to shim the legs up. I used small pieces of pickets from a stockade fence to shim a few legs. If you go on youtube you can see rectangular Intex pools setup. Plywood seems to be the best thing to put under the large side legs. I would bet that a small plastic saucer would work well on regular round Intexs.
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    True, they might be overdone. We were thinking of going with two 2" x 6" boards since we have a rectangular pool.
    Jun 2012
    MA
    347
    Why do the boards need to be 2" thick? Do you think that a 1" thick board will bend or snap or even a 1/2" or 1/4" thick board? The board is laying flat on the ground. That being said there is nothing wrong with using a 2" thick board.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If I recall the intex manual says 1.2" thick boards...which is an odd size. 2 by's are 1.5" (which is what I would use or pavers) and 1 bys are 3/4".
    22,549
    1.2" is referred to as 5/4 (five/quarter) and it's common decking size.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Good point...I forgot about decking.
    nelson411's Avatar
    Aug 2011
    Northern California
    165
    Thanks y'all,
    We decided to go with 2 x 12 x 8 boards. I saw in someone's post that they used one long board so that all of the supports are on the same level. I saw in the manual that they were suggesting 15' by 15' board squares, but I think we can get away with that size.
    I'm incredibly challenged when it comes to DIY, so I appreciate all of the comments and support.
    I will post pictures when we start building. I'm going to attempt to put in a through wall skimmer, and hopefully build a small deck.
    I can't wait until it's set up! My kids are asking every minute when will the pool be up!!
    TFP is the best!
    Have a great 4th of July!!
    Cheers,
    Liz
