Thread: Converting back to saltwater
    I've recently moved into a house that a friend inherited and the pool has a swg system already installed. The pool guy inexplicably started using liquid chlorine in the pool and shut off the swg system. So the pool has been lc for over a year now. We want to revert it back to using the swg and have a question:
    1. Do we need to empty the pool and refill it before turning the swg back on?
    Is there anything else we should do?
    Butterfly's Avatar
    South Carolina
    Re: Converting back to saltwater
    Welcome to the forum
    A SWG pool is a chlorine pool. Just the method of introducing the chlorine is different.
    Post a full set of test results, tell us how you got them, & we'll help you get balanced.
    We need:
    Borates (if you use borates)
    You're done SLAMing when:
    Feb 2012
    Phoenix, AZ
    You should not need to empty the pool before you turn your SWG back on. A SWG (or more accurately SWCG) stands for Salt Water Chlorine Generator. You are still sanitizing the pool with chlorine..just a different method of creating/adding it.
    Do you have a good test kit? If so, please post results and we can let you know if anything else should be done.
    PS Welcome to TFP!
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    You will likely need to add some salt. Assuming the SWG was working when shut off, you should be good to go, with maybe a Salt Cell cleaning for good measure.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    Different brands of SWG require different levels of salt. TEST your pool BEFORE adding any too!
