Thread: How much chlorine to add for the weekend?
    I am heading out for the weekend and I'm not sure how much chlorine I need to add to the pool to compensate for the two days I'm gone. And do I need to cover my pool or leave it uncovered? My levels are as follows
    FC 4
    PH 7.5
    CYA 40
    -J E F F-
    Intex 14' round 48" deep above ground pool
    HTH 6 way test kit
    Intex Krystal Clear Sand Filter 1600g/hr
    I live in southwest Missouri
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: How much chlorine to add for the weekend?
    I'd raise it to shock value for my CYA level and cover it.
    Butterfly's Avatar
    South Carolina
    10,045
    Yep, what woody said ^^^^
    You're done SLAMing when:
    Spiccolli's Avatar
    May 2012
    Gold Canyon, AZ
    63
    anything else you can do if you do not own a cover?
    1992 15X30 14000 Gal IG plaster, Pentair 011018 - Intelliflo VS Pump with Timer, 350 lb Sta-rite hrpb30 sand (yeah, the 32-bolt clamshell)
    Butterfly's Avatar
    South Carolina
    10,045
    You can google 'vacation', bottom left, and get lots of info.
    For a weekend, we just bring to shock level on Fri nite, filter for an hour or so, shut it down and leave. No cover. No problem for us.
