Thread: Adding salt
    Oct 2007
    Jacksonville, FL
    22
    Adding salt
    Is it ok to add salt in the evening with the pump off? Will leaving salt resting on marcite for 15 hours damage the marcite? It would be more convenient if I could just dump the salt in and let it slowly disolve at it's own pace.
    Thanks
    21K - marcite - inground - Autopilot 48 SWG - 240 sq ft Pentair filter - 2hp 2sp Pentair pump - solar heater
    Re: Adding salt
    You can just dump the salt in, but you should run the pump for 24 hours after adding, and have your SWG off or tuned down to zero percent during that time.
    Jul 2011
    Arizona & California
    803
    Re: Adding salt
    Salt that is dumped into pools will probably dissolve adequately without causing any visable damage to marcite finishes. However, it is known that leaving concentrated and undissolved salt on cement/marcite surfaces can be detrimental in time. I suggest brushing salt around until dissolved.
    38,284
    Re: Adding salt
    By the time you brush around the pool once the salt should gone. Only takes a few minutes for it to dissolve.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    Re: Adding salt
    With out the pump, the salt will dissolve, but it will not mix into the bulk pool water. Instead concentrated salt brine will sit in contact with the bottom of the pool until the next time the pump is run (or a long time passes). It is best to run the pump.
