Results 1 to 12 of 12
Thread: Forbidden from Pool Calculator
    nikaboli's Avatar
    Jun 2012
    Pontiac, Illinois
    13
    Help...I need to see how much bleach to add and last night and this morning I can't access the pool calculator. Is it just me?
    Thanks!
    ~Nichole~
    17K, AG, Vinyl, 2HP Pump, Sand filter 80 GPM Design Flow Rate
    Pool is in Full Sun after 11:00am-Sunset
    nikaboli's Avatar
    Jun 2012
    Pontiac, Illinois
    13
    Re: Forbidden from Pool Calculator
    NM...I found a temporary copy on another thread!
    ~Nichole~
    Jul 2011
    Austin, Texas
    78
    Same here. HELP!!!!! Fix it, please!
    30K IG, Plaster with spillover spa, 9 ft deep end with spring base diving board
    48sqft DE Filter, 3HP VS motor, Hayward SPII, Raypak RP2100 Propane heater
    AutoPilot Pool Pilot Digital with SC-60 and pump relay (220v)
    Polaris 280. Pentiar Booster Pump, TF-100 Test Kit, Speed Stir
    Austin, Texas (It's hot)
    Apr 2012
    Yakima, WA
    58
    Can you post a link to the thread please?
    Dave
    Yakima, WA (the Palm Springs of Washington!)
    IG kidney 14k gal, 33 x 18
    vinyl liner
    200 lb Sand filter
    3/4 HP pump
    First time pool owner
    nikaboli's Avatar
    Jun 2012
    Pontiac, Illinois
    13
    calc.html
    That should work! Should have linked to it earlier, sorry about that!
    ~Nichole~
    While you can access the URL posted, it doesn't calculate anything. At least it doesn't on my iPhone. I'll try it on my PC and see if there is any joy there.
    nikaboli's Avatar
    Jun 2012
    Pontiac, Illinois
    13
    Oh boo...it works on my macbook anyhow. There is an iphone app you can buy for the pool calculator. Which I was loving until my 2 year old gave my iphone a bath.
    ~Nichole~
    Oct 2011
    New Caney, Texas
    414
    Save a copy of it locally that way you always have it
    I opened page, clicked on view source, Ctrl + A (to copy) then pasted it in notepad and save as Pool Calculator.html
    Then you can click on it and Open with (I use Fire Fox)
    18' x 42" Intex (4786 Gal @ 80% capacity) Intex 8110 SWCG, 2000 GPH cartridge filter.
    Full Sun, Well Water, Borates at approx. 50
    TFTestKit-100--The Pool Calculator--Pool School
    Quote Originally Posted by dpleticha
    It works just fine on my iPhone. It is a little tedious to use the web version on a phone, but it worked for me.
    22,542
    It works from here now.
    david_22_33's Avatar
    Mar 2012
    Whittier, Ca
    29
    Thanks! I was looking all over for a post regarding this, looks like it got buried by newer posts.
    30,000 gallons, Aquarite salt system, 72 sq ft Hayward DE filter, Stonescape Pebble finish, Hayward Eco Star Variable speed pump (water fall), Hayward Tristar Variable speed pump (pool),
    Hayward 400,000 BTU Heater, 7' high rock waterfall/mini grotto/slide, 80 sq ft Baja bench, Belgard pavers and coping, Hayward LED colorlogic light
