Results 1 to 17 of 17
Thread: Pink foam under AGP
    Pink foam under AGP
    Is the pink foam only used under Intex pools? I'm interested in using it under my liner, but in seaarching, I see the majority of users have Intex pools. Heading to HD tomorrow to walk on it see if I like the feel.
    Thanks
    ___________________________________________________
    27 x 52 AGP, Hayward EC50 DE filter, 1.5hp 2 spd, 16.7k vinyl
    TF100 w/SpeedStir
    Freshman year in Pool School and BBB.
    22,550
    Re: Pink foam under AGP
    It can be used under any AGP. It doesn't have to be an Intex.
    jimmerz's Avatar
    Jun 2012
    Pittsburgh, PA
    169
    What is this pink foam and how expensive of an add on is it?
    24' x 54" Oceanic Round AGP, 1090 Hayward Skimmer, EC-40 Filter system, Automatic Chlorinator. Pool will be in Full sun for most of the day (9am-6pm).
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    My buddy has a permanent AGP (not Intex). He has the foam under it and it is real comfy on the feet!
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Bama, I read a post you were thinking about using it on your sisters pool. Ever do it?
    TF100 w/SpeedStir
    1 brand is called foamular at HD. Haven't priced it out yet, but heard its less than hhappy bottom
    TF100 w/SpeedStir
    22,550
    We just used a gorilla pad under hers.
    Aug 2011
    Virginia Beach
    295
    2 packs of ¼" fanfold for an 18' pool ran me around $80. It's been a month, and I can still feel it under there.
    Intex Ultra Frame 18' X 48" 7600 +/- gallons
    Columbia 50 LB sand filter/½ HP pump, $$ WELL spent(2nd best thing bought for the pool)
    Virginia Beach, VA
    TF100 test kit- Money WELL spent (best thing I've ever bought for the pool)
    Leisure bay hot tub
    Mar 2012
    Central Illinois
    5
    I used 1.5" pink foam on a 24' pool I put up last month. I believe it was in the $250 dollar range.
    I'm not sure how I feel about it. You can definetly feel where the seems are. You cannot see them, just feel them. What worries me is the liner getting into the seams and causing a leak. Its too soon to tell if this will happen, just feels like it's possible. I made sure to get the seams tight and put 2 layers of duct tape on them.
    In hindsight I feel it may be best to put down the pink foam and the happy bottom over it. This may give you the feel of the foam, which is great, with less seam issues. Expensive though.
    Time will tell how it works for me.
    Good Luck.
    24' X 54" Sharkline Matrix 13,500 Gallon AGP
    Pentair Sand Dollar SD35 Filter w 50 LBS of Zeobest
    1 HP Dynamo pump
    TF-100 test kit
    Installed 05/18/12
    Jun 2011
    Midwest
    6
    We used 1-1/2" pink foam under our 18' round AG steel wall sharkline pool last year with about 4 rolls of duct tape. Then duct taped the foam cove on top of the pink stuff. We used Liner Guard (thick felt) ordered on line, on top of that.
    Trying to remember if it went pink stuff - liner guard -cove
    Or pink stuff - cove - liner guard
    Anyway lots of duct tape, maybe I should have used more, but no problems yet, feels good under your feet.
    Not sure what the cost was we got it at Home depot or Menards it came in 4' x 8' sheets.
    It was not tongue and groove, but we wanted that at first, I thought it would stay together better without gaping, I don't think tongue and groove came in the thickness we wanted.
    You can kind-of see the foam seams when dirt gathers there, but I just vac along the seam and it's gone. Less than the liner seam. We have no folds or big ridges and a solid color blue liner you can see all the dirt on the bottom. Seemed that the lines were more visible last summer, maybe it settled or stretched or maybe I was more worried whether we installed it correctly or not last year.
    Great so far! Hope that helps.
    having trouble getting the picture to attach.
    18ft round x 52in wall AG, 8,000 gallon, partly sunk in hill, paver patio,
    Doheny 1hp, 75sf cartridge filter, Kreepy Krauly EZ vac
    installed ourselves July 2011
    Jan 2010
    Randleman,NC
    620
    Quote Originally Posted by slicky5150
    Good Luck.
    Thank's for the input.Will keep that in mind.Ground around here is hard..Plus, pool been in for 13 yrs.Couple yrs ago I replaced the liner&was going to remove all the sand&put padding&foam coves in .But,I didn't..
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Jun 2011
    Midwest
    6
    Here are the pics of ours
    Jun 2011
    Midwest
    6
    and 2 more pics
    Thanks for the input. I'm having trouble seeing the pics on my phone. Can't wait to see them on my computer.
    Thanks again.
    TF100 w/SpeedStir
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I used 1.5" extruded polystyrene foam (the pink stuff) under my pool without anything else on top other than the tape on the seams (used gorilla tape]. I had a lot of roots, and so far no problems, it is holding up great and most seams can not be felt or seen.
    Aug 2011
    Virginia Beach
    295
    If I had it to do over, I'd tape the seams. I've been noticing the dirt settling into lines on the pool bottom, today it dawned on me that it's the untaped joints in the fanfold. Very thin lines, but they're there. They vacuum up with no trouble though.
    Virginia Beach, VA
    Leisure bay hot tub
    MrsFusion's Avatar
    Jul 2010
    SW Iowa
    80
    I agree with big_kid. My hubby didn't tape all the joints and we get debris gathered in the lines. But, it is very easy to vacuum up.
    5,000 Gallon 16'x 48" Intex Ultra Frame, Waterway 1hp sand filter, Intex SWG, AquaCritter, TF100
    Climate/Location: SW Iowa
