Thread: Cannot access http://www.poolcalculator.com/
    Jun 2012
    Cottonwood, Arizona
    12
    Have been getting the following error message all day when trying to access the online pool calculator. It worked for me yesterday. Hmmmm
    "Forbidden
    You don't have permission to access / on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
    26,700 Gal 18x36x5.5 Vinyl Pool
    Pac Fab Triton II TR-50 Sand Filter with Zeobrite media
    3/4 HP A.O. Smith E-Plus Pump (labeled HP=1.3?)
    Currently using pool cover to keep chlorine use down and temps up.
    Apr 2011
    Lynchburg VA
    393
    Re: Cannot access http://www.poolcalculator.com/
    There is an issue with it, here is a temporary one...
    calc.html.
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Jun 2012
    Cottonwood, Arizona
    12
    Thank you, Thank you. A million thank yous as I need to shock and I had no idea how much to add.
    I too THANK YOU,for I couldn't access pool calculator either. Also shock needed. This site is so Great. Thanks again.
    20X40 IG,33,000 GAL,VINYL LINER,1 HP PUMP,HAYWARD SAND FILTER,CAMDEN,S.C.
