Results 1 to 11 of 11
Thread: Pool Calculator Not Working
    Just starting a pool and need to figure my chemicals out but the pool calculator is not working. I'm unable to pull it up.
    Thanks
    17500 gallon Sharkline Morada PUR RTR 18X40 54” tall, 1.5 Hayward cartridge filter,
    Jun 2012
    NJ
    50
    Re: Pool Calculator Not Working
    You're going here?: http://www.poolcalculator.com/
    It's working for me...
    24,000 gallon in-ground plaster, Pentair FNSP60 60 sq. ft. DE filter @ 9,000 GPH, 2HP WhisperFlo pump, CircuPool RJ45 SWG, 399k BTU Raypak heater, built 2008. Taylor K2006C kit.
    Forbidden
    You don't have permission to access / on this server.
    Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
    This is what I get when I click on the above link
    I am also getting a 404 error now (though I wasn't a few minutes ago).
    GreatCanadian's Avatar
    Jul 2011
    St. John's, Newfoundland
    844
    Ok. I was wondering if it was just me. Will keep checking.
    13'x22'x52" 8,000 gallon ProSeries Pool with Borates
    Intex 110 pound Sand Filter with Zeobrite, 2650 gph pump, 0.95 hp
    Bestway SWG
    AquaPro ECO500 50,000 BTU heat pump
    GLI Whirlwind Solar Cover Reel, TF-100 Test Kit
    Jun 2012
    NJ
    50
    Yup.. just came up 404 for me as well.
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    just checked worked for me.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    I'm getting the 404 too.
    Can anyone who is getting access tell me what adding 48 oz by volume of dichlor to a 50,000 gallon pool will bring the FC level up to? My algae problem is back and I need to shock ASAP.
    50k gallon - Triton TR 100 Sand Filter - IG - Marcite - 1.5 hp pump
    I have a temporary copy up at http://www.troublefreepool.com/calc.html. If they restore their copy I will take this one down.
    22,553
    I get 403 & 404 here.
    I hope they get it fixed soon.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Dieter
    Will raise FC by 4, raise CYA by 3.6, lower pH by 0.15, & add salt by 3.2. Sorry, couldn't help myself with the extra info.
    You're done SLAMing when:
