Results 1 to 9 of 9
Thread: CYA level and SWG
    CYA level and SWG
    I have an SWG and an outdoor pool with full sun along the whole day, usual temperture range is in the 90's
    The recommended CYA level in the SWG manual is 40 ppm.
    I read here that the recommended level is 70 ppm.
    Can someone shed some more light on this topic?
    Avi.
    Intex round metal frame 15' x 42"
    Intex SWG / 2000 gph cartridge filter
    Taylor K-2006 test kit
    Outdoor pool with full sun all day long
    Typical temperture range in the 90's
    38,251
    Re: CYA level and SWG
    Higher CYA levels better protect the low levels of FC generated by the SWG from the sun.
    More info is available in pool school articles.
    Posted with Tapatalk ... sorry if I sound short ... hate typing on phone
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    My Intex SWG lists lower than recommended CYA also. I went with 50ppm's, my unit has no issues keeping the FC at a constant by running 4 hours a day in my 18'x33' pool. 3.5 hours would be optimal but it only does 1 hour increments. My pool is almost always covered so that also helps keep it up too. I just test a few times a week and adjust the time up or down as needed.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Dec 2011
    Gold Coast, Australia
    57
    CYA level and SWG
    The main reason, as I understand it, for the higher recommended CYA levels on this forum is to reduce pH rise. Having more CYA means you can reduce run times on the SWG, and by reducing the associated aeration (as the water flows through the cell) it helps contain pH rise.
    37000 litre, concrete, pebble, Viron P300 pump, Hurlcon VX7T SWCG, Viron CL-400 Cartridge filter, Solar heating, Pandora Smart Robotic cleaner
    Sep 2009
    Greentown, IN
    914
    I haven't kept my CYA at 70 this year either and am keeping up with the chlorine demand w/5-6 hours a day. I tend to keep my chlorine on the higher side of normal too. You can try to run at a lower level and see how much you are running your swg and go from there. You can always add more cya, but removing it... what a pain!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Dec 2011
    57
    CYA level and SWG
    sorry... probably not 'run time' speaking technically because run time is more determined by filtration needs. I mean chlorine output percentage on the SWG which determines the time the SWG is generating chlorine. More CYA means less chlorine loss an less chlorine demand.
    Dec 2011
    57
    CYA level and SWG
    Like suziqzer says, I'm actually running at about 50ppm CYA and only running the SWG 4 hours a day on the lowest pump flow an the lowest SWG output and everything is perfect. It winter here and the small pool is getting no use, but the point is you don't HAVE to have 70ppm... just monitor things and adjust accordingly
    The lower your CYA level, the shorter the cell lifetime will be.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Intex says a lower number, maybe so it won't last as long...I don't know. It's cheap enough to replace it after a few years. These little guys are on or off, no percentages here.
    Mike
