Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: Cloudy water in SWG pool
    Pysiek's Avatar
    Apr 2012
    Frankfort , Illinois
    419
    Hello Guys
    I have my SWG setup for about a month right now. At the beginning the water was clear but now it slowly start to get cloudy. I have never work with the pool chemicals except the chlorine.
    Two days ago I've ordered the TF-100 kit. And last night I added some stabilizer (CYA) to the pool. I did use a method that somebody described here. I put 1.6lbs of stabilizer into the sox and put it in the filter skimmer. But the weird thing is that it dissolves after 4 hours of running and some guys said it will take days.
    Also I've read the Water Balance for SWGs tutorial from "Pool school" and have a question. When the kit arrives I should adjust the chemicals in the order the tutorial says or differently?
    My setup is Intex Krystal Clear 1,600 Gallon Sand Filter and Intex Krystal Clear Saltwater system.
    30'x54" Quest Above Ground Round Pool , About 21,000 Gallons , Hayward Perflex EC50 D.E. Filter System 1.5HP Power-Flo Pump , TF-100 Test Kit , Two Hayward Main Drains on the Bottom , Hayward CL200 In-Line Above-Ground Chlorinator.
    77"x77"x21.5" Hot Tub
    22,553
    Re: Cloudy water in SWG pool
    Once you get the kit and run the tests you can adjust the levels according to the article.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Sounds like you'll have to shock, without the kit it's tough to keep the levels right with SWG. Once you get a system down though they are great. Post your numbers when you get the kit.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Pysiek's Avatar
    Apr 2012
    419
    Okay guys. First of all I'm very surprised that the kit arrives in 2 days.
    Here is my results:
    FC - 0.5 or below
    pH - 7.2
    TA - it was about 40 drops = 400
    CH (vinyl pool) - about 40 drops = 400
    CYA - about 20
    Now its time to read the whole article. Unless somebody can help me
    Pysiek's Avatar
    Apr 2012
    419
    Also should I do the test with filter and SWG running?
    Butterfly's Avatar
    South Carolina
    10,045
    How many gallons is the pool?
    You're done SLAMing when:
    Pysiek's Avatar
    Apr 2012
    419
    7600
    Butterfly's Avatar
    South Carolina
    10,045
    Thanks, and please add 7600 gallons to your sig for info.
    Well, you need to follow the directions in Pool School for how to shock your pool: pool-school/shocking_your_pool
    You will need bleach/liquid chlorine to shock. Shock level with CYA of 20 will be FC of 10ish.
    I suggest that you turn the SWG off until you are completely done shocking.
    After you are done shocking, you will need to raise the CYA level.
    Post back here if you have any questions.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    How about the CC level? This should help you with your next steps: pool-school/shocking_your_pool
    Mike
    Pysiek's Avatar
    Apr 2012
    419
    Can I use the shock powder from homedepot?
    That depends. If it is cal-hypo, it will add CH, and your CH level is already as high as you should let it go. But if it is dichlor, then using some might be convenient, as it will add CYA which you need. But don't use too much or CYA will go too high and CYA is difficult to lower.
    Pysiek's Avatar
    Apr 2012
    419
    I added one 1lb bag of this shock: http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
    22,553
    That's dichlor it adds 9ppm CYA for every 10 ppm FC you add.
    Pysiek's Avatar
    Apr 2012
    419
    So how much should I add? I'm really sorry for all that questions but I really don't know nothing about the chemicals
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Your last test result said 20 CYA, if you only put one bag of dichlor then your CYA is now around 29 per Bama's info. You can keep adding it but that means your shock level needs to rise as your CYA rises. You are ok to do this but you don't want to go any higher than 70 on the CYA. This is why it's best to use regular bleach only in the pool for shocking unless you know you need more CYA and know what the new shock level will be. The poolcalculator and your test kit should be your best friends during this process.
    Mike
    Pysiek's Avatar
    Apr 2012
    419
    So it looks like I need to go shopping
    Pysiek's Avatar
    Apr 2012
    419
    Okay. So it looks like I need to shock the pool. But... when I enter the results in pool calculator it tells me to replace 35% of my pool water to lower CH. So should I first shock the pool with bleach or replace the 35%?? Also is it necessary to replace the water?
    Pysiek's Avatar
    Apr 2012
    419
    Quote Originally Posted by MikeInNH
    I did not check the CC level. Will do it today.
    Is it okay to do the test when its about 100F outside? Or should I wait till the sun go down?
    22,553
    The only reason the PC is telling you to lower the CH is that you have the target set to a lower number than the CH result. 400 is a little high but not too high.
    Is your TA really 400. That's extremely high, and it's odd that it matched the CH.
    I'd run the tests again today (it doesn't matter if it's 100º) and post the full set of results.
    Also test your fill water for;
    pH
    FC
    TA
    CH
    That'll tell us if there's any need to drain because of CH.
  20. Back To Top    #20
    Pysiek's Avatar
    Apr 2012
    419
    I will retest it today. I don't remember which test it is but the one that I need to add drops until the solution turn red (this is when I put in 40 drops). I remember that the solution turn pink but I was keep going until it turn solid red.
