would like to convert from Bacquasil
DebMC
0
Jun 27, 2012
1
Owatonna, MN; 15x26 oval above ground pool; 12,6000 gal.; sand filter; Artisian pump 1.0hp
I would like to convert from Bacquasil and have read all your info. My question is ...I have drained my pool down to about 1' of water and cleaned it out the best I can. Should I clean sides and skimmer, etc. with bleach before I refill or go ahead and refill and then start the bleach process? I haven't purchased a test kit yet - can't do much until the pool is full!!
Order the kit before you do anything. The pool will be down for a few days, so enjoy it while the kit is being shipped. Next fill your pool up as normal. Don't worry about scrubbing at first.
After you get the kit start the swap....post any questions you may have. :)
