Results 1 to 9 of 9
Thread: Out of town for 10 days
    Anyone have any tips for keeping my pool in working order despite the fact that i will be gone for 10 days? I will throw a few pucks into the automatic chlorinator, which i do not normally use except in cases where i am on vacation. I will put a solar cover on it to reduce water and chlorine loss.
    I am Most concerned about the PH rising considering that i have been battling scale and need to keep in the low 7s according to the CSI. Any tips for keeping PH at an acceptable level? Doesn't help that the pucks also raise the pH i think.
    appreciate any advice you may have
    Southern California/sun all day
    26k gal/in-ground plaster/jacuzzi spillway
    dual speed 1.5/2.5 Hayward
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    Wife in bikini and Margarita maker
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Out of town for 10 days
    Trichlor pucks are actually adicic and will lower the pH.
    Do you have someone who can come by and check on the pool?
    You're done SLAMing when:
    unfortunately no one can check on the pool. Good to know about the pucks, that makes things a bit easier. Wish there was an automatic Muriatic Acid dispenser, or liquid chlorine dispenser.
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    22,548
    Your best avenue is using the pucks. That will add FC and help control the pH.
    Mar 2007
    San Rafael, CA USA
    12,082
    10 days will still be a stretch for the pucks if you only have a floating feeder. If you have a large inline chlorinator, then you can probably fill it up enough and set it low enough to last for 10 days (maybe even for 2 weeks, but probably not more than that).
    i have an inline chlorinator.
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Quote Originally Posted by Sausage
    You should be good to go. Fill that chlorinator up and have a nice trip.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    An inline chlorinator basically is an acid dispenser. The entire time you are using stablized chlorine such as trichlor it will be adding acid which will lower your pH. For most pools this would always be a good thing (as pool pH tends to rise) and there would probably be no need for the BBB method if it weren't for the fact that it will also be adding cyanuric acid at the same time.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    thanks a bunch.
    Cartridge Filter
    UV Ozonator
    Inline Chlorinator
