Results 1 to 9 of 9
Thread: Leaking pool light suspected
    Our Sylvan in ground pool leaks about an inch of water per day and after fixing and ruling out several other possibilities we believe the leak to be in the recessed Sylvan light fixture. I saw some pictures of the Sylvan light in another thread and was wondering if the leak is determined to be where the wires penetrate the pool wall (with a food coloring dye test) how best to plug and seal the leak?
    I was thinking of leaving the wires intact and applying epoxy putty around them at the wall should that be the location of the leak.
    I/G Concrete w/spa 24k or 30k Gallons (I think lol)
    DE
    Nature2 thingy disabled
    Polaris 280
    Aqualink RS4
    22,553
    Re: Leaking pool light suspected
    You see people here use epoxy to seal the conduit all the time. As long as you realize that you'll never be able to change the light fixture.
    Nov 2011
    Moberly,MO
    1,010
    There is a company that makes a cord stopper that you install around the cord then push it into the conduit. It sells for around 5 to 10 dollars.
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    The light itself doesn’t turn on and trips the GFI which happens to be the switch we use for on/off. I’m suspecting some type of wiring corrosion assuming a blown light bulb itself isn’t enough to trip the GFI. The bulb has never been changed and we’ve never removed the light from the niche so this will be the first time in 37 years.
    I was in the water today with a scuba mask checking the light out and this looks like it’s going to be a little project. First I need to use food dye to see if the light is where the leak is and if not I will be happy just to leave it alone. Getting the light out of the niche and up onto the deck shouldn’t be too hard. Applying the epoxy putty inside the back part of the niche where the wire penetrates the pool wall might be tricky because we have water in the pool. Not impossible though.
    DE
    Polaris 280
    Aqualink RS4
    Back in the water again and discovered that by wiggling the light with two fingers it just pops right out. No tools needed. It looks exactly like the Sylvan light in the pictures in this thread pool-light-for-old-sylvan-pool-t45374.html . I used a big wad of epoxy putty to seal the gap around the electric cord so that the light can be used again at some point in the future after the burned out bulb is replaced.
    This operation was very time consuming as it was performed underwater and holding my breath. Afterward I made a note of the water level and, knock on wood, it will be the same level tomorrow morning. We’ve been losing about ½ inch of water per day so if the leak still persists it will be obvious.
    If all goes well I still have to jam 4 feet of electric cord back in the niche and pop the light back in the fixture.
    DE
    Polaris 280
    Aqualink RS4
    After 48 hours we’ve only lost about 3/8” of water and I’m attributing this to normal evaporation combined with wind and swimming the past few days. Next task is to replace the 2 pool light bulbs.
    DE
    Polaris 280
    Aqualink RS4
    22,553
    Looks like you've found it. Glad you got it fixed.
    It’s been over 3 weeks since I last added water to the pool and I can say now with certainty that the leak has been repaired. We’ve lost almost as much water in the span of over 3 weeks that we used to lose every 4 days.
    DE
    Polaris 280
    Aqualink RS4
    22,553
    Great news.
