Results 1 to 7 of 7
Thread: Replacing plunger valves on Intex Easy Set
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    We know one of our plunger valves has a problem because when you shut them to change the filter, the water flow never stops. It is certainly much less than fully open, though. Thought we could get by with it this year as we have gotten pretty quick at swapping out filters and not much water is lost. However, flow rate has now decreased some and swapping out filters does not increase it. I am wondering if one of the valves isn't quite opening up all the way or some other problem. So, since we have two problems, I decided to go ahead and order new valves.
    Any suggestions on how to swap them out without draining the pool below their level? I thought I saw mention of someone using a bowl someway, but I couldn't find the thread.
    ~~ Allison ~~
    Intex 18' x 48" Easy Set Pool, approximately 5455 gallons
    Krystal Clear 1500 GPH Filter Pump Model 56635EG - 635 with Auto Timer
    BBB FOR BEGINNERS ~ THIS IS A MUST READ FOR ANYONE OVERWHELMED!!
    steinholder's Avatar
    Mar 2012
    Wichita, KS
    81
    Re: Replacing plunger valves on Intex Easy Set
    I replaced the return valve (higher one) by just being prepared (and quick!). It's a good one to practice on because there is less pressure on the higher valve. I did it because my new valves with my replacement pump (2500gph) did not have the plastic debris screen over it, I needed an aerator.
    22'x52" AG Ultra Frame Intex - 12,500 gal (47K liter)
    Manual Liquid Chlorine - 1HP 100# Hayward sand filter
    Lots of sun, trees, pollen & wind - 50ppm Borates
    4nd season grateful TFP fan
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    Quote Originally Posted by steinholder
    Thanks for the hint!
    ~~ Allison ~~
    Mar 2012
    Wichita, KS
    81
    I suppose if you didn't have a need to replace the inside piece, you could try a soft rimmed bowl and hold onto the thread outside (retaining the inside piece). I did see how this could be possible, but i needed to replace both inside and outside.
    Good Luck!
    Quote Originally Posted by aa62579
    I have to replace both of mine. I was wondering if I couldn't first remove the inside retaining ring, place a plastic disk or piece of plastic, cut to fit and replace ring on both intake and outflow. Then wouldn't I be able to remove the outside assembly and replace it without losing much water? I don't have the new ones yet, but I was just thinking about the problem that was presented with changing them out. Any thoughts?
    Mar 2012
    Wichita, KS
    81
    Just try the return first, you will learn what you can and can't do replacing that one.
    aa62579's Avatar
    May 2011
    North Central Texas
    409
    I expect my parts to come in sometime this week, but might be next weekend before we have a chance to try anything. Will share how it goes.
    ~~ Allison ~~
