Results 1 to 7 of 7
Thread: Filling Pool with WELL WATER Please Help
    I put up and filled my pool with well water ( ONLY WATER SOURCE ) in March and still batteling with iron!!!!! I have spent $600 in chemicals since March and need help someone please tell me what to do or where to go!!! I have salt chlorinator!! Im about to loose my mind!! 24X52 above ground not Intex sand filter pool!!
    topher's Avatar
    Jun 2012
    toronto, Ontario, Canada
    136
    Re: Filling Pool with WELL WATER Please Help
    my water is orange comming out the well.. try tuning your filter off and see if it'll settle down and then vaccum up the particles.. it works for me.
    13500 gallon AG, build late 90's, Hayward S220T sand filter,1Hp aqua coastal
    Gasser BBQ broilmate 155154 LP, Smoker CGK (akorn)
    Jun 2012
    Swisher Iowa
    15
    I filled my 20x48 ag pool on the 21, and I have added a total 3 16 oz metal and stain from hth at Wally world, my iron is soooo bad from well, I saw that some one said try a paper towel in skimmer basket , well a roll later that was getting old, I have now gone to a 5 gal bucket of fresh water and few old wash clothes,pretty raggedy so I can keep good flow going , and a few of my type of pool filter cartridges , ( intex stuff ) but I have gone out hourly and swapped out wash clothes and filters, a very smooth fast process, and it's nasty nasty, but I think I am getting a grasp, so that I an gain control on my FC and build up cya , Since I'm still in my shocking process
    Its been a nightmare, I think if or when I have to drain I will plan on buying water somehow, bottle water woulda been cheaper .... But this wash cloth and filter deal is hopefully a decent plan to rid the well water iron ..
    Good luck !!!!
    22x52 pro series steel frame new 2013 /10.5k / Intex Sand filter (new) 3000gph /1hp /well water/ tf100 kit w BBB method
    topher's Avatar
    Jun 2012
    136
    ii'm thinking of getting a slime bag.. gonna try those out. However they are not that easy to get in Canada - not sure why?
    Jun 2012
    Swisher Iowa
    15
    Slime bag .. ?? Something easier to catch this stuff?? Details please))))
    Jul 2007
    Hillsborough, NC
    526
    First, adjust your pH to 7.2-7.4 and CH to 200-220. Keep the chlorine generator going - you don't want an algae bloom as well as rusty colored water. Next, go get some Jack's Magic Purple Stuff. For your pool, add at least 1.5 quarts, let the pump run overnight. The water should be a lot lighter in color. If it isn't, add half a quart at a time, keep the pump running and see if it changes color. My pool took 2 quarts. The best way to add it is dip some water out of the pool with a bucket, pour the Jack's into the bucket then pour that into the pool in front of the return. It will take at least a day for the water to completely clear up once you get enough sequestrant in. After a few days of the water being clear, backflush the filter. I struggled with high iron in my pool water and went through 6 different products over 4 seasons until I discovered Jack's.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    Main reason why I DON'T use my well water to fill my pool (plus it would take a month to fill). I buy my water, comes chlorinated right from the city.
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
