Thread: Does the TF-100 Test Kit also test for Bromine?
    I just discovered this forum and it has a lot of great information. I apologize in advance if this has been asked before, but I couldn't find the information.
    I have both a hot tub and a pool. I use Bromine in the hot tub, so I'd like one test that I would be able to use for both the pool and hot tub.
    Does the TF-100 Test Kit and/or the Taylor K-2006 also test for Bromine? (there was no mention of this in the test kit instructions). If so, would I just follow the same directions as testing for the FC and CC to obtain the respective Bromine levels? Does Bromine also get broken down like chlorine and has the 3 different forms: free bromine, combined bromine, and total bromine?
    Thanks in advance!
    Inground 14'x19' vinyl pool
    Emerald E550 (2008 model) Hot Tub
    Montreal Canada
    326
    Re: Does the TF-100 Test Kit also test for Bromine?
    Perform the test as though you were testing for chlorine, then multiply the result by 2.25.
    Or you can get the bromine reagent, R-0872.
    You still are testing combined chlorine with R-0003 though, even with bromine.
