Results 1 to 8 of 8
Thread: patching 3/8" hole in 2" PVC pipe
    By mistake to placed the water temperature sensor in the wrong pipe in my pool system. No I need to patch the 3/8" hole in the pressure return pipe. Anyone have any idea beside cutting and putting on a coupling? I was hoping of getting some thing I can use with a pipe clamp.
    In the pool business and finally succumbed to building a pool....
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: patching 3/8" hole in 2" PVC pipe
    How about cutting a coupling in half, gluing, then clamping.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,052
    How about installing a flowmeter in the hole?
    Otherwise I'd cut it and install a coupler or a Tee with a hose bib on it. That makes it easy to drain or to hook up an aerator sometime in the future.
    22,553
    I'd just thread it and put a threaded plug in it. In fact that's what I did!
    Quote Originally Posted by bobodaclown
    That's one of the options I envisioned doing.
    Can you elaborate what tools I'll need and what plug? It's a 3/8" hole.
    Quote Originally Posted by Richard320
    flowmeter. That's also a great idea. Does it fit a 3/8" hole or do I also need another hole.
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    in threading all you need is a tap and die set for a 3/8" or larger hole and find a plug with the same thread. Same with the flowmeter find out what thread it has and then tap for that thread. When you plug it, use some plumber's tape prior to plugging.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
    22,553
    The flowmeters I've looked at either need a 5/8" hole or a 3/4" hole to mount through. So you'd have to drill the 3/8" hole out.
    Feb 2008
    Milford, CT
    333
    You can use a PVC saddle tee, or the first suggestion of taking a coupler and cutting it in half and using it as a patch over the hole.
    The tee outlet of the saddle tee can be centered over the hole, the saddle is then glued and clamped to the surrounding PVC pipe. Then just put a PVC plug in the tee outlet and you'll be all set.
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
