Thread: Help with pool cover repair
    Jun 2012
    Long Island, NY
    13
    Hello all,
    I have a Coverpools automatic pool cover, installed under the coping two years ago when the pool was built. Recently, I noticed two tiny holes (?possibly by a stray cat watering itself after rain?) in one end of the cover which allows small amount of pool water to seep through when the pool is covered (cover unretracted). I could not find the piece of the cover given to me by the installers (I must have thrown it out). I just spoke to someone at Coverpools customer service who is sending out a small piece of the fabric to me. I have to glue a small piece of the fabric to patch the two small holes. Does anyone know/recommend the type/brand of glue that I could use? Can I use crazy glue?
    Thanks.
    Han
    25' x 50' IG Gunite pool (~40,000 gallons) with "cool blue" diamondbrite, Jandy 2 HP pump, Pentair TR 100 sand filter, Jandy EE3000T heat pump, Jandy Aquapure 1400 SWCG, Coverpools automatic cover, Polaris, Jandy Watercolors LED pool lights
    Long Island, NY
    Re: Help with pool cover repair
    Your local pool dealer will have the right glue you need.
    May 2012
    4
    As twmackey said, your pool cover dealer should have some vinyl, water-resistant glue that we supply. If the holes are small enough (smaller than a pin hole), you can use the glue by itself without the patch. Contact Cover-Pools if you need to know who your dealer is.
