Thread: Hard cover walk on winter cover?
    Some one needs to figure this out. I would pay a couple grand for one. Fiberglass or something light weight and strong. Modular, like 22 ft by 4 ft or something? Anybody heard of such a thing. I know companies install portable plexiglass ones for weddings and what not but I want one that i can keep, set up myuself each winter, and be able to use it like any other deck.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Hard cover walk on winter cover?
    Fiberglass you could walk on at thoses dimension would be heavy! You'd need a grid and many support posts. You design points in a new pool build to support the weight and not damage the pool like maybe how they do umbrella holders. Take hours to assemble I'd bet....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Nov 2011
    Moberly,MO
    1,010
    Would be more to the tune of 10 grand. That would be an elaborate system and almost need a crane due to weight to assemble
    Over 30 years in the pool business
    We build vinyl, fiberglass, stainless steel pools
    Certified in Hydraulics
    Aren't the regular black safety covers 5-10 grand? I can't imagine what something that would be strong enough to be regularly walked on would cost.
    May 2011
    Orange County, CA
    696
    The issue is the span length and the though that you could never be certain the whole bridge wasn't overloaded with a bunch of people. For a 22' span, we're talking some serious I-beams. Aluminum truss might work if the load was distributed with poles or, in a pinch, foam floats.
    38K in ground pool with attached spa. Current equipment: Easytouch 8 (521150) with IC-60 SWCG with web control by Autelis, 1x Pentair IntelliFlo 011018 pump (for filter), 1x Pentair 2HP WhisperFlo pump (for waterfall), 2X Pentair IntelliBrite 5G 12V lights, Pentair MiniMax400 NG Heater, Pentair SMBW2060 DE filter. Zodiac Barracuda MX8 cleaner on dedicated cleaner line. Lighting/home automation controlled by Insteon/ISY-99i.
