Thread: PentAir cartridge filters
    Diver's Avatar
    May 2011
    South of Boston
    450
    i'm looking thru PentAir cartridge filter selection on their website and there is no clear explanation of the difference between different model lines.
    It seems that Clean & Clear Filters might be for AGP, but i'm not sure if that's the case. Is C&C Plus for IGP? How about C&C RP? There is also Posi-Clear, system 2 and system 3.
    Can someone give me a quick rundown on the model line?
    26K In-ground Vinyl Pool | Hayward DE4820/SP0710XR50 filter | 1.125 HP Dual Speed Hayward Super Pump | Aquasol Solar
    Re: PentAir cartridge filters
    First, Pentair has two brands: Pentair and Sta-Rite. Several of their filters come in both brands, which basically duplicate each other, though there are trivial differences (like the color).
    Clean & Clear - smaller filters.
    Clean & Clear Plus - mid-sized.
    Clean & Clear RP - a redesign of the Clean & Clear Plus line. These are new and will eventually replace the Clean & Clear Plus unless problems come up.
    Dynamic - Designed for spas.
    Posi-Clear - basically the same as Clean & Clear (Plus)
    Posi-Clear RP - basically the same as Clean & Clear RP
    System 2 - Medium to mid-large filters.
    System 3 - Large filters.
    Diver's Avatar
    May 2011
    South of Boston
    450
    Jason, thank you for your answer. So is there a consensus on C&C Plus vs C&C RP? Is it too soon to consider RP since it's still new? Is C&C Plus becoming obsolete at this point?
    edit: it looks like RP filter sizes are much smaller than Plus line. Is it because RPs are more efficient? What would be a good size for 30k gallon pool?
    The RP is very new. I haven't heard anything about it yet pro or con.
    Get the largest size you can afford and have room for, 300 sqft or larger. Larger filters are slightly more efficient and can go longer between cleanings.
    22,551
    Actually the Clean & Clear RP is a redesign of the Clean & Clear, not the plus. The plus is a larger filter than either the Clean & Clear or the Clean & Clear RP.
    My sister has a C&C 200 ft² and I was thoroughly impressed the first time I opened it up to clean it. It is very easy to open and get the cartridge out and in and then to reassemble. I'm sure the RP will be just as easy.
    Diver's Avatar
    May 2011
    South of Boston
    450
    that makes sense - RP only goes to 200 sq. ft.
