Thread: newbie----how do I know when alagae is gone and I can let FC
    I posted on this site last week and thanks for all the help I received in getting my shocking process correct. I think I am almost there as the pool is clearing up, still a little cloudy, but can pretty cleary see bottom drain at 8'. My info and questions are as follows
    - my FC is at 12
    - my cc is at 0
    - my cya is at 50-60
    - my over night FC (oclt) did not drop more than .5
    - Is the little bit of green I am seeing on my filter dead algae?
    - should I soak my filter as per the commets in the filter section or will the high levels of FC and my everyday filter cleaning do the job?
    - when do I stop the shocking and filter cleaning process
    pool was built in 5/11, in ground 37,000 gallon concrete/plaster pebble sheen finish. STA-RITE system 3 Cartridge filter 400sqft filtration area, .288 gpm/sqft, 115 gpm flow rate. also has a Nature 2 mineral sanitizer and a 1hp sta-rite pump
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    Re: newbie----how do I know when alagae is gone and I can le
    Stop shocking when three things occur at the same time.
    pass OCLT
    Water clear
    CC .5 or less
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Keep it up - you're sooooo close! Shock level for 60 CYA is 18, get FC up there for another day at least.
    There is in inverse relationship to this - the last little bit takes a lot longer than the first huge changes. Toss any pool toys or tools in the pool while you're at shock level. Scrub the less obvious places, like inside the skimmer, maybe pop the light out and clean the niche behind it.
    Really, you're almost done, don't slack off and coast. Consider that the last bits of green you have are the hardier strains of algae; they've survived how many days of mega-chlorine?
    You'll know when you passed "the water is clear" part. It will be clearer than you ever thought possible. And once you're there, it's simple to keep it that way.
