Results 1 to 7 of 7
Thread: What gel to use?
    Sep 2007
    Toronto
    106
    What gel to use?
    I need to lower my water to change a LED bulb, the lens is a screw-on type with a gasket, I remember there is a gel I need to apply on the gasket for water-proofing, does anyone know what I should use? Thanks.
    OH TWINS
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    Guest
    I believe you are talking about a silicone or teflon based lubricant for pool use such as MagicLube (teflon) or MagicLube II (silicone). These are what are commonly applied to o-rings, gaskets, etc to protect the rubber and make a good seal.
    Jan 2008
    Forney, TX
    162
    Well if you have an LED and it is burned out there's no bulb to replace. You have to replace the entire unit. This also entails pulling the old wiring as the whip is hardwired to the fixture. I wouldn't recommend doing it yourself unless you're comfortable with pulling wiring through a conduit (not as easy as it sounds!)
    Our pool adventure... click here
    Guest
    Some LED units are screw in types to convert older fixtures so it might be possible to 'change the bulb"
    Sep 2007
    Toronto
    106
    My LED plugs into a socket which is connected to a wire in a conduit. I do have a tube of Teflon made by Locktite, I guess I'll use it on the gasket. Thanks everyone.
    OH TWINS
    Guest
    You want a speciality product made for pool use like I suggested above. I would not use the loctite product. You can get a suitable product from your local pool supply or from an online supplier.
    Sep 2007
    Toronto
    106
    Alright
    OH TWINS
