Thread: Upgrade????? Sand or swg
    Jun 2012
    Swisher Iowa
    15
    Hi yall i have a New pool , 20x48 steel frame, w a stock skimmer filter thing pump sfs1000, 1075 gph ..week into it and it's clear I need to upgrade quick, It falls far from circulating anything , I don't need whitecaps but general visual movement wouldbe great
    Advice,
    1. My pool is made by polygroup / pro series pool, does intex products work with my type
    2. How big HP would anyone recommend,
    I've seen the Hayward pumps in 14,16,18,21,and so on..
    3. Bad well water issues, would swg or sand or de bea better fit
    4. Conversion kits, skimmer basket and hose sizes ??
    Hints and precautions welcome
    22x52 pro series steel frame new 2013 /10.5k / Intex Sand filter (new) 3000gph /1hp /well water/ tf100 kit w BBB method
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Upgrade????? Sand or swg
    Quote Originally Posted by Iowawaterbabies
    Not sure of your brands fittings, but I have never plumbing that can't be adapted.
    I've seen the Hayward pumps in 14,16,18,21,and so on.. ]'quote]You do not want a big pump, a 3/4 hp max...you may want to consider a 2 speed. As for filters, for sand you would want >1.5 sq. ft, for a cartridge filter you would want >120 sq. ft, and for a DE filter you would want >22 sq. ft. (some would say 11 is enough though).
    Cartridge might be the best fit since you do not backwash that type of filter. SWG (salt water chlorine generator) is not a filter, but a way of getting chlorine in your pool automatically. SWG's work with all filter types.
