Thread: Are my test results even close to where they need to be??
    Jun 2010
    Levelland Texas
    125
    Hello everyone....
    Here are my results from tonight....
    FC: 6
    TA: 110
    Cya: 50
    Ph: 7.9-8 (that is taken with OTO drop kit from Walmart as I realized I had the T-50 test kit)
    CC: 0 (from this morning and this evening)
    Water is clear, temp about 82 with a little dirt in the bottom (always in West Texas).......
    I know "how" to lower my ph.....but what I don't know is how to "KEEP IT DOWN"???
    Can someone respond with advice on where my results are???
    Thanks in advance!! :P
    New 22' round, 52" deep Coleman (Bestway) AG/10,500 gal/16" Intex sand filter with over the side skimmer/Levelland TX (Lubbock area)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Are my test results even close to where they need to be?
    Your results look decent. Your ph is high, you can keep adding acid when ph goes up to 7.8 to bring it back down to 7.2 and this will slowly lower TA which should slow down your ph rise. You can lower TA more quickly using this approach: http://www.troublefreepool.com/pool-...l%20alkalinity
    30,414
    Jun 2011
    Long Beach, CA
    2,781
    I believe your pH will tend to rise to 7.8ish due to having a SWG. Lowering your TA might help to slow down the rise.
