Results 1 to 7 of 7
Thread: I think we want to get a saltwater system
    Hi guys,
    I am new to the forum, and we are just putting a pool in at our place. I think we want to get a saltwater system, but I don't know much about them. OUr contractor has given us the following options and prices. ARe they good options?
    We are putting in a relatively small inground, 15 x 23' oval. Planning to heat is as we are in Canada
    Here are the options he gave us:
    Choices:
    1) Hayward AQ-TROL-RJ-CUL Salt Water Chlorine Generator - Up to 18,000 Gallons - $889 plus HST. Salt and Installation - $200 plus HST.
    2) Pentair IntelliChlor Salt Water Chlorine Generator - Up to 20,000 Gallons - $1,463.00 plus HST. Salt and Installation - $200 plus HST
    Are there big differences? I know that there are TONNES of options, so I thought I'd try a forum to see if these are good recommendations/prices or if there is something better we should ask for.
    THanks!
    Marissa
    1) 34,000 Litres (yes, we are in Canada)
    2) Sand filter
    3) Inground
    4) Vinyl
    5) (not sure of pump size...sorry!)
    Aug 2010
    Dallas, TX
    4,052
    Re: Which SWG to get?
    Do you know the volume of your pool? The bigger SWCGs, to a point, are more efficient and can last longer than one that's specific to your pool size. I don't know the conversion from Canadian to US dollars, so I have no idea if those are good prices or not.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    654
    I have the Intellichlor 40,000 gallon model on my 14,100 gallon pool. They said bigger was better.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Mar 2012
    Mountain Brook, AL
    112
    Re: I think we want to get a saltwater system
    Yes, get bigger than you need. Then you can dial the % down and not run it as hard. They do say it will last longer. You want everything on a digital timer as well. Those models may have built in timers.
    Consider solar panels to heat the water if you have a place to put them. They are awesome.
    13,500 gallon IG Diamond Brite Super Blue, Pentair Superflo 1.5 HP 2 speed pump, 300 lb Hayward Sand Filter, Hayward Swim Pure+ SWG, Four 4X20 Fafco Solar Bears, Jandy Lite2 NG Heater, Borates, Blue Diamond Robot, TF100 & Refills, Taylor SpeedStir
    The pool will be ~ 9000 gallons, so not that big. No real deep end...just 4-5' deep.
    I pointed out to our pool guy that the aqua trol was marketed by hayward for above ground pools. He said that this was marketing, and that it is more important to size the generator correctly. The Aqua Trol is good up to 15000 gallons. Also, since our pool is appropriate for inground or above ground installation we should be fine. He makes a good point, saying that the water is the same, the chlorine demand is the same--the generators just depend on volume of water being serviced. Makes sense to me. However, I had concurrently sent a note to the manufacturer, and they said "DO NOT put the Aqua Trol for an inground pool. It is not created for in-ground pools due to the lack of a flow switch which would lead to an accumulation of gases inside your system. It is configured for above ground pools so that gases can escape in the pool."
    Very confusing for a new pool owner!
    Also, do you need a special heater for a saltwater pool? One that resists corrosion?
    Thanks!
    usagi
    2) Sand filter
    3) Inground
    4) Vinyl
    You can get the aqua trol from amazon for $460. The price you are paying you should be getting a aqua rite system.
    http://www.amazon.com/gp/aw/d/B002EL40N ... mdp_mobile
    Aqua rite
    http://www.aquasupercenter.com/products ... 0System%20%2020K%20Gallons~32318.html?ccd=gp&utm_source=AQ-RITE-20&utm_medium=cpc&utm_campaign=google+products&sa=X&ei=1w3rT 7aPMI-q8AS0l6zvBQ&ved=0CHMQgwgwBQ
    18x36 Grecian Vinyl; 8' Roman steps w/t 2 spa jets; cozy cove w/t 6 spa jets; 2 MD, 1 Skimmer, 3 returns; Hayward Ecostar, 30" Ranger sand filter; Hayward color logic 4.0 LED light; Hayward aqua logic; 2" PVC pipe 4 Jandy Valves
    ultra800_96's Avatar
    May 2009
    Pomeroy, Iowa
    225
    I bought the Aquatrol for my 24' x 48" ABG last year. Seems pretty adequate for my 13,000 gal. I run mine around 45% & works great. Bought it for $400+ change from a supplier in the members section on this site. Installation was a snap. Very easy. But my pool isn't open year round here in freeze country, so hoping I get some years out of it similar to the larger units on year-around pools. I will agree though that usually, bigger is better.
    Yes, I was going to mention about the flow switch issue. The RJ (return jet) model needs to be installed vertically so it can outgas directly to the pool. They do make one though that does have a flow switch. I believe it's the HP model & should have a flow switch included.
    12,900 Gal. 24' X 48" ABG Vinyl Round (17th Birthday)
    1HP Hayward Pump w/S180T Hayward Sand Filter
    AquaTrol RJ SWCG 2011 startup
    TFP Method since '09, TF100
    50ppm Borates, June '12
