Thread: Recommended level for lots of direct sunlight?
    Jun 2012
    NJ
    40
    The recommended level in pool school says to ask for advice for a bunch of things.
    We have lots of direct sunlight - there are no trees to shade it.
    What do I need to do differently than the recommended levels given in pool school?
    NJ
    35,000 gallons, DE filter, IG plaster
    TF-100
    Re: Recommended level for lots of direct sunlight?
    The only real difference is to make sure you are at the high end of the recommended range for CYA, or just above (don't go above 60).
    38,267
    May just want the CYA at the high end (closer to 50ppm).
    What are your current levels?
    Do you have reason to be concerned?
    Jun 2012
    NJ
    40
    ok thanks!
    no problems, just getting everything set up - added cya a few days ago so going to wait a few more days to see where im at
    NJ
    TF-100
    Jan 2010
    Randleman,NC
    620
    I have direct sunlight all the time..Never had a problem..Run my CYA at about 30 when opening up...I bump it up when it get Summer..Now running about 45..I do keep a solar blanket on to keep the temp up&keep's the pool cleaner.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    neen01:
    My pool is in the full Texas sun much of the day. I am currently at 30 CYA. If my FC consumption were to spike (and I have confirmed that there are no other issues causing this), then I would add more CYA. So far, though, that has not happened. Of course, every pool is different and regular testing is the only way to do what's right for your pool. I tend to be conservative with CYA and like to leave a little "room to grow" in case I go on vacation out of town and am forced to temporarily use trichlor pucks if I cannot get a trusted adviser to look after the pool while I'm gone.
