Thread: Installing a 3-way pvc valve to tigerflex hose
    Mar 2007
    I am trying to install a 3-way pvc valve to my tigerflex return line an a tigerflex
    line to a jetted tub. I am using pvc primer and glue. When I put the return line
    into the valve and hold for a minute it pushes its way out.
    When I dry fit the lines they seem fine. When I add the glue it pushes itself out.
    Any ideas? Thanks
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    When you put together a PVC joint the glue starts reacting and it will often push back out to some extent. If you can hold onto it and keep it together for twenty seconds the reaction should stop and the glue will lock up.
