Results 1 to 7 of 7
Thread: Adding DE disaster! Sucks to be a noob
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Backwashed my filter last night. Got plenty of Georgia red clay out of it from the build. Added the 5 cups via dumping most in the skimmer and some in front of the slimmer. What didnt get sucked into the skimmer I thought would dissipate and get filtered out. Came home to a pool floor covered in DE....actually had to manually vacume god that is time consuming!!! Now I got to run the filter 24/7 to clean up the cloudiness...can still see across the pool underwater but it's not as sharp of an image...
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    38,246
    Re: Adding DE disaster! Sucks to be a noob
    So what did you do incorrectly to get that result? Was the DE making it through the filter or were you on recirculate?
    I have never had this problem.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I think because I'm only running my pump for about 6 hours and it turned off shortly after I added the DE that it settled out on the bottom, and then couldnt be filtered out without something stirring up the water. That or the filter is messed up, but when I vacummed today the returns where clear....
    18'x43' Sport Pool
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    When adding DE, I put about a heaping tablespoon at a time into the skimmer. The water in the pump basket will turn white. I wait for pump basket view port to clear up and then repeat. Using this method you should not see any coming out of the return. If you see it coming out you're probably pouring it in too fast or something is wrong with the internal plumbing of your filter.
    Quote Originally Posted by harleysilo
    16k gal, 28'x3.5', Vinyl A/G, 1hp Pentair Dynamo 2-speed Pump, Hayward S160T Sand Filter, Intermatic HB800RCL Digital Timer, Intex 8110 SWG, TF-100 Test Kit, SpeedStir Author: Jesse's Graphical Pool Testing Log
    38,246
    Man Jesse, that sounds like it would take forever
    I fill up a 2.5 gallon bucket with the correct amount of DE. Fill the bucket up with water and make a slurry. Dump it into the skimmer ... not usually very slowly either. Dip the bucket into the pool a few times and swish it around until all of it has gone into the skimmer. I have never seen any DE come back to the pool and I do not typically add it on Rinse either.
    JesseWV's Avatar
    Apr 2011
    North Central WV
    526
    Well since I have a sand filter I use less than 1 cup, so it's pretty quick. I would assume that you wouldn't have to go so slow if you have a DE filter?
    38,246
    Quote Originally Posted by JesseWV
    Ah that is the confusion. harleysilo and I have DE filters. I think you have to go slow with the sand filters to check the pressure rise.
