Results 1 to 9 of 9
Thread: Vacation??
    Jun 2011
    Frisco, Texas
    70
    Vacation??
    I will be gone for 10 days and i'm trying to figure out what I can do to minimize issues with my pool. I don't have anybody that I can ask to look at it. Is it ok if I increase my FC up from 5 to around 7 or 9? And can i reduce my PH to about 7.0 when I leave?
    33'x21' In-ground (23,000 gal) - 8' spa raised 18" with 8 jets | Filtration Jandy DE 60 | Sanitation Aquapure 1400 SWG | Pumps Intelliflo VS+SVRS 3.0HP & Jandy 1.5HP stealth water feature pump | Heating Jandy LRZ400 | Lighting Jandy LED Spa (1)/Pool (2) | Coping Tennessee Crab Orchard & Moss Rock | Finish pebble sheen type (riversand) Tahoe Blue
    30,403
    Re: Vacation??
    What is your CYA?
    Jun 2011
    Frisco, Texas
    70
    Re: Vacation??
    CYA is currently 65.
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Vacation??
    [EDIT] The following assumes no automated dosing. I missed reading that there is an SWG which should maintain chlorine levels automatically. [END-EDIT]
    If you've got full sun, then with a CYA of 65 you may lose around 35% of the FC each day (is that how much you lose over 24 hours?). Even if you raised it to 20 ppm FC, it would drop...
    20 ... 13 ... 8.5 ... 5.5 ... 3.6 ... 2.3 ... 1.5 ... 1.0 ... 0.6 ... 0.4 ... 0.3
    and usually when it gets very low it may go away completely and not just be a proportional loss. By shocking higher (say to 26 ppm) one can usually go for almost 7 days, but 10 days is a stretch unless you cover the pool with an opaque pool cover.
    You might consider having Trichlor in a floating feeder, though that usually doesn't last for 10 days, but if you put it on the slowest release setting it might help for those last days.
    Another thing you can do is to add Polyquat 60 in a larger initial dose. That also won't last for too long, but it will still have some remaining even after one week. You'll need to dose with it first, then shock with chlorine, then bring the chlorine back up after a day or two since some of the Polyquat will react with the chlorine.
    Jun 2011
    Frisco, Texas
    70
    Re: Vacation??
    I do get full sun. But, with my SWCG I don't currently lose that much FC. But, we just started the 100 degree weather and I don't know what will happen to my FC if it stays that hot. How high should I raise my FC? How low should I bring my PH?
    38,246
    Re: Vacation??
    If the SWG is maintaining FC, what is the concern? That is one of the benefits of the SWG. If you are worried, just turn the % up a bit. OR just bump the FC level up to shock level with bleach and let it slowly drift down since the SWG will still be adding FC.
    I would lower the pH to about 7.2 if it tends to rise.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    651
    Re: Vacation??
    I am confused. With a SWG, chlorination should not be an issue while you are gone. If concerned about it, increase the rate and/or your pump run time. You might consider lowering PH a little, if it tends to creep up over a normal 10 day period.
    Am I missing something?
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jun 2011
    Frisco, Texas
    70
    Re: Vacation??
    My main concern was I don't have any expeirence with the pool yet and wanted to know if I should raise the FC up with bleach (to make sure I don't have any problems). I'm just concerned with what % to raise my SWCG since we just started with the 100 degree weather. I currently have it at about 70%. I was thinking I would raise it up to 9PPM with the help of bleach.
    I'll lower the PH to 7.2
    XsAllOverIt's Avatar
    Dec 2010
    Mount Airy, Maryland
    560
    Re: Vacation??
    If your SWG is maintaining your FC correctly each day now, don't do anything. In 10 days, you should have the same FC level. The only issue is if it stopped working, which isn't really an issue.
    18 x 36 Inground Gunnite, White Plaster 21K gallon
    18" raised spa, 8' Diameter (620 gallon)
    Triton II Sand filter, Intellichlor IC40 SWG
    Pentair Pump, Max-E-Therm 400 BTU
    Lamotte ColorQ PRO 7-Plus test kit
    TFT-100 test kit
