Thread: pork questions
    pork questions
    please see this post ASAP!!
    TIA!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    What's wrong with putting a loin in a crockpot? I make mean shredded pork tacos this way. Rub it with spices, cook it slow all day and throw some chili peppers in adobo sauce with a little tom. sauce at the end. Yum :P The recipe calls for shoulder but I can never find it so I use loin. 8)
    No Cover Charge
    17,000 gal IG w/ raised 8' spillover spa, 3M plaster, 10' stainless rain WF, Pentair SAM lights, Sta-Rite Sys3 cart. filter, Intellichlor SWG, 400kBTU Gas Heater, Paramount IF Cleaners, ET-8 Wireless Remote
    Molson's Avatar
    Apr 2008
    Midland, Ontario
    479
    Shoulder is also referred to as a butt roast, or picnic roast (2 roasts of a shoulder) Loins are leaner and should be cooked at higher temps. But if it works for you, then great!
    40 x 16 IG Vinyl. Goldline SWG
    160 Sq Ft Roof mounted solar array
    2014 Hydropool Serenity 5000 Hot Tub
    The Pool School- A great place to start
    Jason's Pool calculator
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Mermaid,
    The next time you have a whole loin and need ideas, just post your address and some of us will be right over to help you :P :P :P
    Yum, yum
    You're done SLAMing when:
