Results 1 to 8 of 8
Thread: shocking
    shocking
    We had some issues with our salt pump not working consistently so we now have a slight algae problem. Got a new salt pump and now I plan to shock the pool this evening. My question is how long after putting the shock treatment in do I need to vacuum?
    38,248
    Re: shocking
    I think you should start by review some of the Pool School articles (button at upper right). Are you referring to a pump or a saltwater chlorine generator (SWG)? "Salt pump" is kind of an odd term
    [shock:340be0vj][/shock:340be0vj]
    Here are some other details about the shock process:
    Defeating Algae
    Turning Your Green Swamp Back into a Sparkling Oasis
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Re: shocking
    jbizzle types faster than me!
    So, um... Welcome to TFP!
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
    Re: shocking
    For lack of better term- we call it a salt pump around here- but technically its the SWG. I've read some of the pool school articles. That's what led me to hoping shocking will fix our problem. Really not sure what we are doing! lol Thanks
    38,248
    Re: shocking
    One key piece of information is your CYA level. If it is near zero, then the SWG will not be able to produce enough FC to overcome the loss due to the sun's UV rays. This will then lead to algae growth which adds even more FC demand and the SWG just falls further and further behind.
    Get one of the recommended test kits
    Post up a full set of test results.
    Then follow the shock process ... once you pass the 3 test to stop
    Post another set of results and we will get you dialed in.
    Re: shocking
    It looks so much better today! We are not green! I will get a test kit as soon as I can- we live quite some ways from a town with a pool supply, and we've never had this problem. Thanks
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Re: shocking
    Quote Originally Posted by tator35
    Yay! Progress! Now stay on top of it!
    Once you have a test kit, and take ownership of your pool, that won't be a problem.
    -Gordon
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: shocking
    Unless it's a big pool store that deals with a lot of commercial accounts, they probably won't have what you need. Save some gas - go to http://tftestkits.net and order a TF100. You might as well spring for the XL option, too. I heartily endorse the speedstir, too. Testing is faster and more consistent, and more fun. Wherever you are in the US, you'll have it within 5 days. Probably sooner.
    And no, I have no financial interest in the company!
