Thread: Pool Party
    jccams's Avatar
    Dexter, MI
    95
    Pool Party
    What's the general rule, keep chlorine at current level then elevate some after party, elevate some before party, or business as usual regarding chlorine level?
    24,000 gal vinyl Lazy L, 1 hp pump, DE Filter, Pentair 250K heater, Letro Legend pressure side pool sweep
    22,468
    Re: Pool Party
    Elevate before party.
    jccams's Avatar
    Dexter, MI
    95
    Re: Pool Party
    Currently keep between 4-8 based on CYA of about 50. What should I elevate it to?
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Pool Party
    Quote Originally Posted by jccams
    I suggest around 10 to 12. I would also test FC/CC & pH after the party
    You're done SLAMing when:
    gboulton's Avatar
    Apr 2012
    Nashville, TN
    380
    Re: Pool Party
    I recently had a party in pretty demanding conditions. 100 degree heat, full sun, 11 kids aged 7-13.
    30 minutes before the party, I brought FC to 12 (normally 9), and lowered pH from 7.5 to 7.2
    At 2pm, After the party, I brought FC back up to 12, checked pH (it was 7.3), checked CC (.5), left the pump running remainder of the day, and all night.
    Next morning, FC was 9, pH still 7.3 water was crystal clear, and I went swimming
    -Gordon
    Pool School helps me maintain my 13,500G 24' x 48" ASP with Sand Filtration using a TF100 Test Kit and Pool Calculator.
    Remember, the Shock Process should be followed until : 1. CC is less than 0.5 ppm, 2. An OCLT shows a loss of 1.0 ppm or less and, 3. The water is crystal clear.
    --I didn't buy my pool to swim in it. I bought my pool to watch my wife swim in it. :wink:
