Thread: Intermatic Pool pump Timer
    Jul 2008
    NJ USA
    146
    My timer made by Intermatic T104R Model ,is acting up, when the ON or OFF clip reaches the time pointer the timer stops and the pump does not turn ON or OFF
    as it suppose to. I can manualy move the silver lever with the words ON and OFF on it to make the pump come on or go off, another clue is when the timer reaches the ON and OFF clips i hear a faint TICKING noise from the timer . any one can shed some light on this issue?
    19000 Gal. Fiberglass Inground 44x18 irregular shape pool
    Heat Siphon heater , Cooper Ind. Ranger Series Sand Filter, 3/4 HP Speck pump, Astral inline Chlorinator
    Aquacheck and TF100 tester
    NJ USA
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Intermatic Pool pump Timer
    Probably the motor of timer mechanism is failing. They are replaceable.
    Jul 2008
    NJ USA
    146
    Thanx John i will look into that.
    NJ USA
