Thread: Pool Construction
    Pool Construction
    My next door neighbor is building a pool and I noticed that the pool builder poured the floor first and no walls. It's been a few weeks
    and still no walls. I am wondering if this is proper construction or will it leak at the wall to floor seam?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pool Construction
    What kind of construction? Is there rebar on the sides or plain steel walls? You typically don't pour a floor for a concrete pool, although some do for a vinyl pool.
    There is rebar on the sides and bottom before the concrete was poured. The owner said he is putting in a salt water pool.
    Jul 2010
    Oklahoma City
    71
    So the floor looks like a big slab? Does it have rebar ends sticking up through the concrete all of the way around perimeter? If so I'd say they are going to form the walls for a "poured concrete" wall rather than a "sprayed" wall. If not, I'd say they will probably erect walls for a liner pool on top of the slab.
