Results 1 to 7 of 7
Thread: other chemicals - harmful or just a waste of money?
    Jun 2012
    NJ
    40
    After being on here the last week I found out that our shock adds calcium and the chlorine tabs add cya.
    Are these harmful, useful, or neither/do nothing....
    algeacide - 60% liquid polyquat?
    stain and scale products?
    nature2 filter?
    I am planning on using the methods on here so just setting up for the future on what we used to use compared to what we will use going forward.
    NJ
    35,000 gallons, DE filter, IG plaster
    TF-100
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: other chemicals - harmful or just a waste of money?
    If you haven't read "Pool School" at the top of the page its a wealth of info. Get a good test kit, I have the TF100. For my setup I don't use any of the products you list. Once the water is balanced and monitored by you, pool life gets much easier.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Jun 2012
    NJ
    40
    I saw that they aren't part of the basics but just wondering if they were ever used (special situation, open/close) or if not, if there is a specific reason to their absence like the added ingredients in the shock and chlorine tabs.
    NJ
    TF-100
    22,542
    Quote Originally Posted by neen01
    Both! If you need calcium it's helpful. If your CH is too high it's harmful. Same thing with CYA.
    There's very rarely a need for it at all. But if you have to have it for some rare situation then that's the one.
    Only need it if you have scaling and then you need to investigate which product to use.
    nature2 filter?
    Don't use it.
    If you're going to manually chlorinate your pool you should use bleach. You may or may not need acid or borax. I'd wait till after running the pool a while and then you'll know what you need to have on hand.
    Polyquat algaecide is recommended for a few special situations, like winterizing and AA treatments.
    Some stain and scale products are good when you have those specific problems.
    We never recommend using Nature2.
    Jun 2012
    NJ
    40
    ok great! - im going to try to get rid of the other stuff i wont be using but ill hang onto the algaecide we have for the winter and i wont buy the nature2 cartridge next year
    NJ
    TF-100
    Jun 2008
    Marana, AZ
    347
    I've occasionally used cal-hypo; just keep an eye on your calcium. I haven't used that, though, for well over a year; decided liquid chlorine was much easier. Since I have a sand filter and backwash, I do use the tabs, but sparingly (about 3 every couple of months during swim season.) This is to keep my CYA up. I use polyquat occasionally during our summer monsoon season when the water gets to be about 90 degrees, and also during opening and closing. Liquid chlorine is my main source of chlorination, and I have found it to be extremely easy. Normally, the only other thing I have to add is about a cup or so of muriatic acid every week or two, as the TA and pH of the tap water is rather high.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
