Thread: DE filter - how often do you take it apart?
    Jun 2012
    NJ
    40
    We have a DE filter - how often are you supposed to take it apart and clean it?
    Is it a certain amount of time or just if it is working differently?
    We are also not handy - is this something we can get a pool store/company to do for us or is it like the water testing in that they would do a bad job?
    NJ
    35,000 gallons, DE filter, IG plaster
    TF-100
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: DE filter - how often do you take it apart?
    I try not to take my Hayward filter apart for the whole season. Usually back flushing it twice then re-coating is enough. I have to do this often in the spring and whenever the pressure builds too quickly.
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    I have taken mine apart too many times to mention but this was before the BBB method. Since the BBB, I have not had algae blooms. I fought them last year but they are not are not an issue this year.
    If you run the BbB method like it is intended too, you may only need to open it once a season. You can pay the pool company to clean the filter but they are pretty simple.
    -- Guy --
    Qwaxalot's Avatar
    Jun 2012
    439
    Quote Originally Posted by neen01
    Typically you backwash a DE filter at 6-8 PSI above the clean pressure, then add sufficient DE to make up for what was lost.
    That said I think it's best to do a complete tear down, cleaning and recharge to spec once a season. This ensures that the DE cake doesn't get to thick or too thin.
    Most any competent pool service company should be able to perform this service.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    WestSidePool's Avatar
    Cincinnati, OH
    424
    I open mine up at the end of the season after I winterize everything.
    It's not hard, just takes some time to clean the grids. If your not comfortable doing this type of work, then yes have a pool service company do it for you.
    Eric
    IG 17x33 Grecian - Vinyl Liner (21k gallons), Hayward Pro-Grid DE 4820 filter, Hayward Super Pump, CompuPool SWG CPSC36, TF-100 Test Kit
