Thread: Temps in the 100's robbing the Chlorine ?
    Aug 2011
    Augusta, Kansas
    88
    A heat wave hit Kansas this week bringing with it the 100's - today is forecast for 110 - what happened to the 90s to get us used to the heat
    I love our SWG and up until this week my FC has been wonderful and staying at a constant 4 or 5 with a CC of .5 when I test around 6 PM with daytime temps in 80s and low 90s. Thanks to you all I've got my CYA at 80 and other than trying to get my pH down which I'd planned on working on this month (from the tap we measure 8.2) I've not struggled with our crystal clear pool...until this week.
    Today will be day 3 in the 100s. Our pool is losing chlorine - could it be due to the AMAZINGLY hot temps this week? The pool is pretty much in the blazing sun from 11 AM to 7 PM. Day 1 of the 100s was Sunday FC was at 1 so I bumped the SWG from 4 hours to 6 hours. Day 2 105 or more - Monday I was still at a 1 so I bumped it to 12 hours. Today's is forecast is 110! So far it's nothing but 100's in the 7 day forecast UGH!
    Is there anything else I should be doing? Though I don't have the other numbers (they are at home) they have been and continue to be constant.
    Diane
    Diane
    15,000 salty gallons - 24' x 12' x 52" Intex Ultra Frame Pool
    Intex Sand Filter, Pump, SWG - TF-100 and speed stir
    steinholder's Avatar
    Mar 2012
    Wichita, KS
    81
    Re: Temps in the 100's robbing the Chlorine ?
    I am using more too. I use 12.5% liquid chlorine and sometimes add two cups in the AM, two cups in the evening. But, we use it all day long, splashing and aerating...
    -Bill
    22'x52" AG Ultra Frame Intex - 12,500 gal (47K liter)
    Manual Liquid Chlorine - 1HP 100# Hayward sand filter
    Lots of sun, trees, pollen & wind - 50ppm Borates
    4nd season grateful TFP fan
    techguy's Avatar
    Jul 2010
    Antelope, CA
    2,687
    Yes, temps that high will certainly burn off chlorine. Your CYA is plenty high so just use liquid sources of chlorine. Just test each night and add whatever chlorine was lost due to the sun or to swimmer use.
    Late late edit... I forgot you are using SWG. You can bump up the SWG, run for more time at your current setting or add liquid chlorine. Your choice and you could leave your SWG setting as is and just add chlorine as needed to augment the SWG (aka both SWG and bleach)
    -- Guy --
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,110
    Best place to start is doing an OCLT. Make sure nothing is growing in the pool. If you're clean, either turn up the SWG or add a few FC's worth of liquid chlorine a day.
