Thread: pools over 50 years old
    rabbet's Avatar
    Jun 2012
    Garrison, NY
    13
    I'm curious to know if there are others in this forum who have old pools. Mine is 62 years old. I'm considering SWG and am wondering if it might be corrosive to my main drain pipe which is cast iron.
    40K gallon IG painted concrete
    no skimmers
    Triton II sand filter
    2 HP Hayward pump
    Built June 1950
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    Re: pools over 50 years old
    Ours is only 28 years old, so plumbed with PVC. It will be interesting to see who chimes in with advice on this one.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Jun 2011
    Long Beach, CA
    2,788
    My guess is that I would not run a SWG with a cast iron main drain, seems like a recipe for a "little" rust.
    Qwaxalot's Avatar
    Jun 2012
    439
    I would totally agree with staying away from a SWCG on a pool this old. Even the SWCG manufacturers will advise you to stay away from stainless steel filter tanks, much less iron or copper plumbing!
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
    Aug 2010
    Dallas, TX
    4,052
    I don't know if my main drain is iron or not, but it's that old. All the plumbing I've been able to see at this point has been copper, not iron. Keep in mind that ships with tons of iron on them go to the bottom of the sea and stay in great shape for ages, and the salt concentration in the sea is 10x what will be in your pool. And, I've had iron pipes rust (sewer) in both my older homes, with no salt present. I'm thinking it's the combination of air and water that rust, not a constant underwater situation.
    My opinion? I am not going to give you one. Contact the SWCG manufacturer and see what they say.
    I put in my sig line that my pool is circa 1960. If it was built when the house was built, it was built in 1954. There was an addition put on my house, including the pool, not too much longer. So I don't know the exact age of my pool, but I can say between it and my irrigation system it's the most copper I've ever seen in my life!
