HELP New Pool (scaling - I think since built.)
Jun 25, 2012
5
I have what i think might be calcium scaling inmy new pool. I have tried lots of chemicals and nothing has gotten rid of it. I have tried an SOS pad and scrubbed it and gotten it smoother but it still feels a bit like sand paper and looks like little bubbles on the sides of the pool.
What do i do to get rid of it?
Thanks in advance!!
Here is one more pic.. Mainly on the walls... when origially brushing the plaster 3-4 times a days when pool was installed In JAN.
I would brush really hard and got most of this stuff off but it seemd to be there from the 1 st week or so.
Pools is 6 months old
approx 13K gallons 15x30 lagoon style pool 3' shallow and 7' deep end.
rock style pool with waterfall.
I seem to have to add about a 1/4 to 1/2 Gal acid weekly to keep my PH down. It was a bit high one week or so over the winter.
Thanks again for all your help!!!
To avoid scaling you have to maintain careful water balance, paying particular attention to TA and never allowing pH to get high. These and your calcium level all play into the CSI (Calcium Saturation Index). Post your water test results and we can suggest ways to get the water balanced.
CH .08
TCH .08
PH 7.1
ALK 86
CYA 52
Salt 2200 ( I added 2 bags of salt per the pool place)
I have been using strips and drop tests to make sure I am in the correct levels evey other day.
Current strip just tested says (good guess since it is not the drop kit.) I do that about once a week.
TH - about 500ppm
TCH - 2
Free CH - 2
PH 7.4
ALK 80
CYA 50
You have posted total hardness. However, we need calcium hardness to determine the saturation index.
What is the highest that your TA and pH have been?
What color is your plaster supposed to be?
I don't know if the test kit that came with my pool tests the total hardness?
I looked on my pool records and I don't see it there either? The ALK says with adjustment.
I think my PH was at or just above 8 at the highest. I added a bucket of calcium per the pool place where i had the pool installed.
Did everything as they told me to do from the start.
