Thread: The Solar Heater Is In
    Jul 2007
    Hillsborough, NC
    499
    2 2'x20' panels. I hooked them up yesterday and tested today. I was skeptical but they do make a difference, the water was a few degrees warmer this evening. The mounting kit was sold as a ground/roof kit. However I discovered Saturday that it is a 'ground kit' provided you have something to mount the brackets too. So I framed and decked a 'roof'. I will take it apart in the fall and come spring when I do the real deck will put it up there as a roof for the panels.
    I don't know why the ripples are there, I think it is because the sections get turned to lock together. I hoped they'd flatten out but they haven't yet.
    The mixing valve. This plumbing is going to get reworked a bit and cleaned up come spring. Also, I am going to re-route the waste line. All those black spots are Permatex-2 sealant. It is supposed to be a replacement for teflon tape. My success with it is mixed. It is also impossible to keep that stuff from getting all over.
    27' Round Might Sun AG Pool 18000 Gallon Intex Krystal Clear SWG Hayward Pump/Filter on a Timer
    Jun 2011
    Savannah, NY
    16
    We have a 16' x 32' pool with a 6-1/2' deep end. I have 8- 2' x 20' panels on my garage roof. I can raise my water temp from 64 degrees to 86 in two days. Of course those would be sunny days! They work very well and would recommend them to everyone.
    16' x 32' rectangle with 4' radius corners.
    Approximately 19,200 gallons
    Hayward sand filter and pump
    ColorQ Pro 7 Test Kit
    Jul 2012
    Michigan
    33
    Re: The Solar Heater Is In
    Is there a certain brand of these that is recommended?
    Also, can someone point me in the direction of the frames?
    Thank you! I'm a soon to be pool owner.
    Kim
