Results 1 to 8 of 8
Thread: Want to raise pH via aeration for TA lowering - get air leak
    Jun 2012
    Louisville, KY
    266
    I am using trichlor for now so I can understand my pool better and how to deal with vacations. Using trichlor I experienced as expected ph drop and was using borax to raise pH and get my TA above 100 via baking soda. Then I got a very small suction side air leak cause returns to be ever so slightly burpy.
    During this air leak my pH maintained a SOLID 7.7, didn't have to do anything, this went on for a few weeks still using trichlor. The air leak was actually raising the pH by the amount lost to using trichlor. Once I fixed the leak, low and behold my pH started dropping and is now down to 7.4. Pump runs 24x7.
    I'm thinking there HAS to be something you could put on a return to cause this kind of airation (TINY bubbles) and help folks when they're trying to lower TA (get pH down, then raise pH via airation). Or get drastic (and I'm not suggesting it), purposefully cause a tiny leak on your pump basket.
    Trying to give back,
    spidey
    FC=7
    CC=0
    ALK=100
    pH=7.4-
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Want to raise pH via aeration for TA lowering - get air
    Yes, you were aerating the water enough to have carbon dioxide outgas faster. Having a higher TA level would also accomplish that as would having a lower pH target (or, put another way, the pH rose until the Trichlor acidity and carbon dioxide outgassing were balanced). While the pH was remaining stable, the TA was slowly dropping over time. Eventually that would cause the pH target for balance to drop and even further down the road could eventually exhaust the TA and have the pH crash. So even with this pH balance approach there is still maintenance required to maintain the TA level. You just didn't see that because you didn't have the air leak for an entire swim season.
    That's an interesting thought regarding creating more aeration for those trying to lower the TA. There are all sorts of aerators, but if someone made a pump lid that allowed for some degree of air to come in...
    Jun 2011
    Savannah, NY
    16
    I took a 1-1/2" threaded connector and added a small piece of pipe, then a 45 and piece of pipe about 24" then another 45. Then another small piece and put a cap on the end. I then drilled 1/2" holes in the cap. I took out my return nozzle on the side wall and screwed this pipe on. Had it above water level spraying into the pool. Aerates perfectly. If I get time I'll post a picture of it.
    16' x 32' rectangle with 4' radius corners.
    Approximately 19,200 gallons
    Hayward sand filter and pump
    ColorQ Pro 7 Test Kit
    Jun 2012
    Louisville, KY
    266
    Quote Originally Posted by chem geek
    I did notice a TA lower from 110 to 80-90 during the few weeks of the air leak, I will be raising it tonight. Adding 4 pounds baking soda.
    Trying to get to know my pool much better, what you said makes sense. I will say the air leak made a HUGE difference in my pools behavior on pH/ALK. Once repaired, everything changed (over days of course).
    I test FC and pH daily, but I'll keep an eye on ALK
    30,421
    Most folks try desperately to stop the intake of air into the pump, not encourage it!!
    I would think that you would lose quite a bit of filtering efficiency and create a lot of pump noise if you purposefully created a suction side air leak.
    That said, from posts here on the forum it appears that that is perhaps the single most common mechanical problem with pools and many people just accept it as normal.
    Jun 2012
    Louisville, KY
    266
    See here for my fix on suction side air leak. I felt like freaking superman fixing it.
    using-plumbers-putty-to-fix-small-air-leak-on-returns-fixed-t47985.html
    I'm not suggesting purposely cause a suction side air leak, only the effects of it.
    Ashbourne's Avatar
    Western Piedmont, NC
    109
    Here's what I built two years ago for my return...brought the pH up from 7.2 to 7.8 in two days.
    download/file.php?id=6372&mode=view
    download/file.php?id=6373&mode=view
    18x36 IG Vinyl, 8.5 deep, 28K, Hayward C4025 SwimClear Filter, Hayward SP2607X10 Super Pump 1HP
    Jul 2011
    Chambana, Illinois
    40
    My pump lid has a black o-ring around it that I can replace for a few bucks. It rests in a groove around the plastic lid. Suppose I bought another o-ring and cut a half inch out of it......
    12,000 gallon IG vinyl pool, 1 HP pump, sand filter, TF-100 test kit, Raypak heater. Converted from Bacqa June 2011. Trouble Free ever since.
