Thread: Quick question on the CYA test
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Thanks to Meg, I received my new (correct) CYA test tube.
    My question is: Putting in drops at waist level until the black dot goes gray or is completely disappears?
    SWG pool at 13,000 gallons and 2 LBS of dry Cyanuric acid via the "sock in the skimmer" method (so far)
    Just need a clarification (excuse the pun) on the dot
    thank you in advance.
    Steve-Liteguy
    13K Pebble-tech Pool, ECO pump, IntelliChlor SWG, DE
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Quick question on the CYA test
    See the pictures in this link where the dot is no longer visible. If you are unsure, you can pour the solution back into the bottle to redo the test as many times as you like, going further to be sure, stopping shorter the next time, etc.
    Liteguy's Avatar
    Aug 2011
    Cave Creek, AZ
    49
    Chem Geek, those pics are so helpful-THANK YOU!
    steve
    Steve-Liteguy
