Thread: draining pool
    Oct 2009
    Southern CA
    54
    draining pool
    May be a stupid question: If I plan to drain the pool in a few days, can I stop adding any more chemicals? been dumping in tons of acid and not able to bring down TA for any significant amount of time. also has low grade algae.
    FC 5-9
    pH rises quickly to 7.8, been unsuccessfully trying to keep it near 7.2
    TA 70-90, not been able to bring down to 60
    CH 680 +
    CYA 60
    salt 3000 (non salt water pool)
    Thanks.
    Irregularly shaped IG pool with aggregates of squares and rectangles, spa overflows to pool
    21K gallon, Pebble tec, 450 sq ft, 125 GPM cartridge filter, 1hp pump, 1.5hp booster pump, Jandy heater,
    2 skimmers, 2 main drains, Hayward Navigator automatic vacuum connected to one of the skimmers
    Re: draining pool
    1. Why are you draining your pool? 2. Why would you add chemicals to a pool you are completely draining? BTW, completely draining a pool is almost never a good idea.
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Oct 2009
    Southern CA
    54
    Re: draining pool
    it's been hard to keep the pool balanced: high TA and pH despite pouring in tons of acid and aerating; not able to maintain a low enough TA/pH to keep CSI balanced; high CH, high salt and frequent low grade algae are other factors.
    Question is if I can let the pool go for A FEW DAYS if it's at least partially drained. Is it easier to deal with a clean startup pool, but waste chemicals now, or is it better to just shock it later when water is refilled. Sorry about the unclarity.
    Re: draining pool
    Do you know what your fill water TA and CH levels are?
    Oct 2009
    Southern CA
    54
    Re: draining pool
    fill water CH 80-90 today, 125 last month
    fill water TA 150-160
    fill water pH >8.2 (bright red)
    do not have salt strip to test fill water. will get it if it's important.
    pool last drained 2.5 years ago, by half, due to high CYA, CH.
    Had very little rain in the winter for dilution.
    best option?
    Oct 2009
    Southern CA
    54
    Re: draining pool
    Do you recommend partial drain or complete drain?
